When we talked on the phone, I wasn't thinking straight, sorry about that. I'm going to assume since there is voltage of some kind at the fuses, that they are the correct voltages, I just had you placing the black lead on the wrong place. However, just to be sure ...
Looking at the schematic (now, and not depending on faulty memory), I see that you need to read the F5 fuse power at the bridge rectifier with your red lead on the red-orange-orange wire and your black lead on the red-yellow-yellow wires. Your meter needs to be set on AC. You should see 12VAC or higher with no load.
Next, we need to know what the DC voltage is coming out of the bridge rectifier. Set your meter to DC and put your black lead on the ground buss. The red lead needs to be on the red-black-black wire. You should see 12VDC or higher with no load.
If you have the correct voltages here and you still have no LED's on the A2 power supply, as I said on the phone, it's very possible that the solder around the input connector pins to the A2 has failed and will need to be repaired.
If you don't have a working fuse in F1, you won't get any displays once the power issue is corrected.
Steve
