I recently traded an EM machine for another. But the one I traded had a short and it kept blowing the GI light circuit fuse. This just so happened to occur after I changed many of the bulbs on the machine. Luckily the trading partner was a lot smarter than I, and he told me it was a short in the strip light socket and fixed himself and was no big deal for him.
With the hope i can ovoid this in the future, I am asking what causes the short on the strip light socket?
It looks like power is supplied on one side onto the strip itself and then return side (is that correct?) is wired to the individual bayonettes.
Also, why does the pin on the bottom side pop out when a bulb is inserted? It seems counterintuitive to me.
If the insulator were to pop out on the bayonette....then you would get a direct short circuit...correct?
If the wire on the bayonette were to make direct contact with the strips metal assembly (see pic) ---then that would cause the short also? Thinking yes to all of these...but dont want to assume anything.
Where would you get corrosion on the bayonette that would cause poor connection? Can you just clean it off with a dremel tool or abrasive pad ?
