Hi Everyone. Gottlieb King Rock is the game. It's a 230V export version. Owner moved it from Lebanon to the UAE (same voltage between both countries) and now the machine blows the main line fuse on power up. History of the machine is unknown but I know the following:
Main line fuse was over-fused at 25A (!!!!) Replaced with 5A slow blow.
Other fuses also the incorrect ratings.
Line cord was old and only the 2-pin type. Replaced with 3 core and added ground connection to transformer. Ground braid to be added later.
Main line fuse still blows on power up and it also trips the circuit breaker at the house.
Since transformers rarely seem to fail I'm wondering if the wiring to it is suspect. Photos attached. Grateful if someone can check transformer wiring on a similar machine and let me know if this one looks right. Perhaps the transformer has failed? Photos attached showing wiring before and after new line cord installed.
I'm generally competent with pinball repairs but less so with EM's. Thanks all.
50E1D45B-BA1A-42F9-897F-A3B66217E50C (resized).jpeg515C6A70-FB8F-4E58-A3EC-5CD980BA297F (resized).jpegDD942FCE-9AE9-419F-88FE-954CCE293E17 (resized).jpegIMG_4316 (resized).jpeg
