(Topic ID: 168827)
Gottlieb King of Diamonds Start Up Help
By heatwave
6 years ago
  • 7 posts
  • 5 Pinsiders participating
  • Latest reply 67 days ago by poppapin
#1 6 years ago
Just put my recently acquired KOD back together after a detailed cleaning/shop out.
It started up, reset score reels and played (with a few scoring glitches) a game. On second start up, game reset score reels, back glass lit up but game shows "Tilt", playfield lights are not on and nothing else happens.
I checked the tilt switches and that does not seem to the problem. What I did notice is that when the control bank resets, the YB (2B-9B Sequence Relay) relay resets with the rest of the bank but then instantly trips. When you try to manually reset it, one of the switches is energized (loud buzz) and the relay instantly trips.
I have the schematic but am only so-so on reading them.
Any help is appreciated. Thanks -
#2 6 years ago
Check the big sequence bank in the head, the one with the cards on it. The bank frame has a wing-nut on each end that engage slots in the end brackets. Over time, the bank tends to slip out of the end brackets and this causes operational problems. To fix, loosen the two wing-nuts, push the bank frame all the way forward into the slot on each end-bracket, and tighten the wing-nuts down very tight.
- TimMe
#3 6 years ago
TimMe -
Thanks. I had gone through the head and the bank is securely in the frame with the wing nuts aligned. I will double check it. Do you know if there is any particular switch in that bank that would be forcing the YB relay to fire?
#4 6 years ago
The YP as descibed fires when 2-9 are made, a daisy chain set of contacts thru the 8 relays will activate that. So it sounds like a short somewhere tripping the YP relay. Check around jones plugs and harness coming off of control bank. I had a sharp lead off of a solder lug pierce a conductor and the game would go into gameover when a feature was made...
As to the tilt, slam switches etc
#5 6 years ago
Turns out it was the rolling ball tilt switch.
I removed the panel holding the ball tilt and fuses when I pulled out the bottom board. When I screwed it back in I must have somehow angled it a little too forward because just lightly nudging the machine caused it to tilt. All is well now. Thanks for those who replied.
I'm sure there will be a few more glitches but the game looks great. Pics of the finished game to follow.
6 years later
#6 67 days ago
Quoted from TimMe:
- TimMe
Ok, this saved me not just tons of time, but f-tons of time. Not knowing to check the wingnuts and bracket would have cost me hours of pouring through the scat and aligatoring my way to oblivion. Imagine my surprise as all my symptoms disappeared after jiggling the end of the sequence bank and it jumps up in the slot and tightens right up. If you have a KOD and it’s acting weird, check the sequence bank out. TimMe you are my KOD savior and I owe you a couple of shots/rounds/hits if you ever bump into me.
#7 67 days ago
Quoted from Bublehead:
I second this! Happened to me too.
The Pinball Scientist
Other
Men
$ 5.95
Protection
$ 89.95
Penny K Pinball
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-king-of-diamonds-start-up-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
