Hi crujones4life
first some theory --- Bally, Williams and Gottlieb schematics are drawn in an "special situation the pin is in". A game for ONE Player has been started, Reset has been done, Ball has been kicked over to the Shooter Alley - ready for the player to launch the ball. THEN the pin is toggled-off and the 110VAC main power cord is unplugged. Steppers stay as is - Interlock-Relays stay as is - Relays sitting in the Control-Bank (or in another -Bank) stay as is. A simple relay pulling before we toggled-off: This / these simple relays loose power (as we toggle-off) - relay(s) let go. And now the schematics (switches) is drawn with / in this situation.
An schematics is drawn "beautiful / abstract" --- the real wiring in the pin can be "other", NEVER, never there is in a pin - from an connecting wire QQ to XX: Somewhere along the wire a second wire forks-off connecting to YY. See the JPG, upper left corner - a fork-off upwards is drawn. Never there is in a pin such an fork-off. I call the drawing the "AA". Towards the left bottom in the JPG You see "BB", "CC, "DD" - examples how it is really wired in the pin --- ALWAYS a solder-lug is used - TWO wires end on this solder-lug.
In the JPG I marked as "EE" and as "FF" other places with "fork-off in the schematics" --- I then doubled the part - and just added "blue question marks" instead of make several drawings "maybe like that - maybe like this".
Theory of operation --- by now You help the pin through the start-up - You manually step the Player-Unit - step - step - step and at a time the unit reaches Home-Position is also position-zero. From now on the pin does the stepping - along my "marked green" wiring.
When You start a new game then stepping is done "partially along red wiring - partially along green wiring" --- the very last step(s) to then reach Home-Position (is also position-zero) is done "ONLY along my green wiring".
Trouble-Shooting --- YOUR pin does not step "early in the start-up" - it also does not reset Score-Drums - does not step "late in the start-up". From this I clue (maybe I clue right - maybe I clue wrong): The wiring in the upper-right corner of the JPG (and leftbound to "my blue FF") is the first place to investigate for the problem "NO STEPPING on start-up".
Maybe it is simple - the "Switch on S-Relay with wire-color-red-white / with wire brown-white" is no good - one of the wires has broken-off or the switch is out of adjustment - never closing contactpoints are oxidated (?) - closing mechanically but "not closing electrically" ?
Maybe when starting the "SB1- and SB-2 in the Control-Bank do NOT plunge and so the Switch "SB2 in the JPG" is faulty open - or its adjustment is no good - or a wire has broken-off (wire-color-brown-white or wire-color-slate-mingled-with-white) ? Maybe the real wiring (remember what I wrote to AA BB CC DD) is "wire-color-slate-mingled-with-white" runs from SB2-switch to Motor-1A switch and has broken-off at motor-1A switch (and there is a wire wire-color-slate-mingled-with-white running direct from Switch-"P" to motor-1A switch (and this wire happens to be good).
Tricky to check --- not easy to describe / write --- I end this post summing-up: I would have a good look in the pin - look at the stuff that is shown in the upper-right corner of the JPG. Greetings Rolf
