Quoted from davidr415:Seems like a good way to go. How far did you move it? A fraction of an inch could mean many things
I can't recall exactly, and I don't have access to the machine right now. Guessing 1/8" to try to keep the old and new holes covered beneath the post base. But before you drill a new hole, try these tricks first (I didn't think of them at the time):
a. experiment with the ring tension by using a larger diameter ring;
a. remove one fat plastic post and just use the thin metal post as a test. It will change the angle of the ring which should be enough to make a difference. If it works, cut/modify the plastic post into 2 pieces to keep the ring from moving up/down.
