Press the start button on the front door
Won't start. Checked slam switchs all good, credits on credit wheel.
does it start with manually pressing the start relay? If so I'd check the contacts on the credit wheel
If it doesnt.. can you press in the hold/tilt hold relays? do you have 24v? (does the score motor complete a 120 degree rotation when moved off of home? A sanity check I always do)
Hi pinhead
Manually pressing the start relay resets all score reels but the outhole relay keeps clicking .if I force the outhole relay to reset the game resets and goes to ball 1 but none of the 3 outhole kickers work.
Quoted from Raff:Hi pinhead
power to the flippers? need pieces of the schematic...
but yea if it starts via start relay the the credit wheel zero contact is probably dirty...
I looked at the switchs on the credit reel and used alligator clips on the middle switchs still did not start . And none of the outhole kickers are working
Gets to the outhole relay and score motor keeps turning.and the outhole relay keeps clicking does not reset.
Quoted from HowardR:Exactly how far is it getting through the startup sequence from the manual?
Quoted from Raff:Gets to the outhole relay and score motor keeps turning.
By "Gets to the outhole relay" do you mean the Outhole relay successfully activates? Or that it does everything up to then and the Outhole relay doesn't activate?
Quoted from HowardR:Or that it does everything up to then and the Outhole relay doesn't activate?
Correct
Quoted from Raff:Correct
Inspect and diagnose this circuit with Alligator clip jumper wires
https://pinside.com/pinball/forum/topic/gottlieb-big-shot-repair#post-6305153
http://www.planetimming.com/Pinball/troubleshooting/EM%20Troubleshooting.pdf
http://www.pinrepair.com/em/index3.htm#features
Example of a pinsider actually doing this https://pinside.com/pinball/forum/topic/red-baron-tech-question#post-5858156
Sorry i got the wrong relay ,
It gets to the u relay and keeps clicking on and off .
It is stuck.on the u relay .
Quoted from Raff:Sorry i got the wrong relay ,
is the start relay cycling in and out? sometimes we can get a stuck coin switch
I ajusted a switch at 3c that fixed the u relay problem.
The start button on the front door is not working.
I have checked the slam.tilt switchs they are ok and I have cleaned the credit wheel switchs.
I'm lost
Quoted from Raff:The start button on the front door is not working.
Since the Replay Button doesn't activate the Replay Button (V) relay,
Problem.fixed
It was the wires on the coin lockout relay someone had removed the relay and left all 3 wires .loose I joined the 2 lighter colour wires together and the start button worked everything came back to life.
Thanks to everyone for helping.
Raff
Anthore problem,
When ball 5 drains the game does not.go to.game.over , have checked the ball count in the.back box looks.good. I noticed that the QB (Game over relay) does not pull in when ball 5 is drained, score motor keeps turning. .
Raff
Quoted from Raff:I noticed that the QB (Game over relay) does not pull in when ball 5 is drained,
Does the Last Ball (XB) relay activate?
Quoted from Raff:the QB (Game over relay) does not pull in
Thanks Howard
I found the A-1118 relay coil at QB was burnt out .
I have ordered a coil just have to wait for it to come.
Raff.
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-jumping-jack-no-start and we tried optimising it for printing. Some page elements may have been deliberately hidden.
