I am trying to learn to be more self sufficient in trouble shooting so if someone is able to point me in the right direction and provide the logic behind the direction I would appreciate it.
Jacks Open set to 5 ball. I was able to fix a couple of issues related to a 2nd chute error and a pop bumper, but still have a couple ongoing issues. Start up is now fine and ball unit registers ball 1. All rollovers, pop bumpers and rebound switches register points immediately when triggered. The first issue is that the drop targets do not register points immediately when dropped. If you knock down the Jacks, the Shoot for Jacks light goes out, but the targets do not reset and the machine does not advance to Shoot for Queens. When the ball drains, the points are added and the targets reset, however, the shoot for Queens does not illuminate. This will continue for all 5 balls. Once the 5th ball drains, the machine sends a 6th ball to the shooter lane, but shows game over and flippers are dead. At this point, if I manually trigger Jacks, the targets reset and add points as they should when a live ball is in play and you can move through the entire sequence. I cleaned all the target contacts and had to adjust a couple since they were making contact when they should have been open. I have the schematic and manual, but obviously I am a bit lost. Ball unit issue, sequence issue relay issue? It seems to me that the issue is somewhere before the reset "ball count" unit since once the ball count unit moves, the targets reset and add points, and I am assuming that when in the 6th position the reset "ball count" unit doesn't come into play?
