Hi all-
I have a Gottlieb hot shots, 1989.
Bottom left of Playfield there’s a “kick save” feature. It is not working. When the light is lit, and the ball rolls over the wire - the appropriate sound is played. Coil doesn’t fire (because the fuse is blown)
Because The fuse blows after the system boots up/game starts I’ve temporarily wired in a circuit breaker in place of the fuse. If I reset the breaker while the game is “in play”, the coil immediately fires and stays energized until the breaker trips (1-2 seconds)
Coil is new (proper Gottlieb parts) diode tests fine. Coil is wired properly
I’m feeling like it’s a transistor failure?
I have replace the “bottle cap” transistor on the small board in the lower cabinet. But i can’t identify if there transistor on the A3 driver board. is there a 2n6043 (or similar) on the a3 driver board in back box?
It’s also strange that the coil for the kick save is not listed as part of the “solenoid test” list.....
I can find THIS assembly listed using EACH of the following terms: (annoying - why different terms for same thing!?)
-kick save
-left our rollover save ball if lit
-bottom left shooter
Any thoughts?
What else should I be looking for.
Thx
Pete
