Hi bonzo71
I do not have an "Hot Shot pin" - I hope another pinsider can help with an picture. Here http://www.pinrepair.com/em/index3.htm#reset is some information.
In the JPG I put together the places in the schematics "SB1-Relay and SB2-No-Coil" --- may want to check in Your pin "what switches You still have - whats missing --- free ends of de-soldered wires , checking the wire-colors and the connections to 'other switches on other stuff' ".
(((A "work around" - taking an spare Relay - wire the switches on this spare relay --- as long as the SB1-Relay in the Control-Bank is plunged: As long You manually actuate the spare relay --- when the Control-Bank does reset: You let go on the spare relay --- I hope You can get the missing parts))) Greetings Rolf
Rolf,
Thanks! I believe there is a single make brake switch and I'm missing wooden spacers and screws. Also, there seems to be an unshielded wire that connects between the relay to the left. With some good photos, i think this is repairable.
Bump....I reallly need some photos of the disassembled switch stack. Any help would be greatly appreciated.
Ok not the greatest pictures but hopefully this helps.
If you ever have issues with the bonus let me know. As rolf can attest I became more familiar with how the bonus works then I had any desire to.
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-hot-shot-missing-reset-bank-partsphotosparts-needed and we tried optimising it for printing. Some page elements may have been deliberately hidden.
