(Topic ID: 51119)
Gottlieb Hot Shot keeps running when pluged in! Need advice.
By Dan329
10 years ago
There are 284 posts in this topic. You are on page 6 of 6.
#251 5 years ago
To start, focus on the zero position switch on the credit unit. Make sure the unit is greater than “0” and that switch is closed. Then focus on switches on the “y” and “s” relays.
If all is right, pressing the coin door button will energize the “y” relay. The “y” relay has a switch that will energize the “s” relay. The “s” relay has a switch that will start the score motor.
Clean and adjust all the switches in this post. Credit unit and “y” and “s” relay switches
#252 5 years ago
Update,I'm gonna need a few days to make repairs,going thru entire machine.they are just to old now.needing a few coils and parts .will order this week.i appreciate you guys patience with me.sorry I didn't have more done .will be back ,hopefully by weds or thurs with machine ready to troubleshoot better.i feel the condition it's in now would be wasting your time.again sorry I wasn't better prepared with my prep work.but will be back this week ready to go.again thanks guys for hanging with me on this.i want to get it running asap,and not let all you piinsiders down.
#253 5 years ago
Pafasa,will pay special attention to relays you mention.and the credit unit again.again thanks for help.please check back this week if possible,so I can keep you updated on progress.again thanks.
#254 5 years ago
It’s all good. Take your time. It’s cold and snowy here. Not going anywhere!
#255 5 years ago
Ok. Now my player one 10k reel isn’t working All others are ok. Suggestions ? I can hear clean those switches in the reel. Correct ? Other tips or remedies? It does work about once every ten times. Ugh
#256 5 years ago
Quoted from Nikrox2:
I would check the switches on the 1000 point reel when its in the 9 position.
#257 5 years ago
Will do tonight ! Thanks
#258 5 years ago
What did you find on your 10k problem nick?
#259 5 years ago
Just getting started on that now. Finally have Pb time! Lol kids. You feed them one time and they want to eat the rest of their lives ! Lol
#260 5 years ago
This is how it’s looking in the 9 position It seems spread apart more than the one next to it which was at 4
#261 5 years ago
Nope. Same as the others when they reach 9. Cleaned the switches. Still not hitting. I’ll keep looking
#262 5 years ago
Let me throw this out there. Could it be one of the relays say L or M? I guess I’m being lazy. I should find the schematics and look it up myself. I’ll get this. Last item on it (again). Lol. This one machine has taught me so much and a joy to fix. Still - thinking of selling her to start on the Double Barrel . Next!
#263 5 years ago
And just like that she’s back ! Just needed the relays cleaned Went ahead and got them all. Want this to be right! Thanks guys!
0BFDB4BE-A2E6-4F4B-98C4-CCA272AB401D (resized).jpeg0BFDB4BE-A2E6-4F4B-98C4-CCA272AB401D (resized).jpeg530222BD-6379-4968-9922-2F08B5359A25 (resized).jpeg530222BD-6379-4968-9922-2F08B5359A25 (resized).jpeg6BF34B5D-EB68-42ED-80F2-67A7AE0D8B60 (resized).jpeg6BF34B5D-EB68-42ED-80F2-67A7AE0D8B60 (resized).jpeg724ECFBA-F92A-49C4-A74A-95711512AB25 (resized).jpeg724ECFBA-F92A-49C4-A74A-95711512AB25 (resized).jpeg
#264 5 years ago
Looks really nice. I love the wear around the flipper buttons. Shows the love this machine got in its prime.
#265 5 years ago
Pretty nice backglass too. Typically, the shooter guy has flaking in his outfit and I can't even see any fade where the anti-rattle foam pieces contact the glass.
#266 5 years ago
Hey guys,just finished under playfield .still have bottom cabinet relays to do and I will be ready to troubleshoot .I should be ready in a few days.hang tight.
#267 5 years ago
Real nice nikrox2,what I noticed about these playfields,they all have a bad spot under the 8 ball kick out on right side of triangle.any one else notice that about these playfields.wonder why?. Any one know story behind it.
#268 5 years ago
Quoted from pinballbrian:
That is where the 8 Ball saucer kicks the ball.
#269 5 years ago
Yep! I’ve left mine as is. It is actually very smooth there (it almost an optical illusion ). It looks like a deep hole. But when I rub my fingers over it still very smooth. So as with the other items on her I’ve tended to leave things original.
#270 5 years ago
Pafasa,(UPDATE).finished going over bottom cabinet relays,ect..going to double check switch adjustments tommorrow and plug in and try to start game.will post results of what happens.found many issues.and repaired.may need a few coils as we go.but have replaced some and have a few new ones if needed.again thanks guys for hanging with me.i think it will work this time with a few adjustments.
#271 5 years ago
Hi guys,plugged in machine.when I did.game started on its own.score motor keeps turning.left drop target bank keeps resetting.and S ,start relay and V,replay button relay( coils) keeps activating .pulling in and releasing.guessing by the score motor.any suggestions on what to do next. HELP!! ha ha.i think it's better than was before.at least getting power thru machine.im going to try again ,see if anything else moves.
#272 5 years ago
Also wanted to say.coil in door moves also,see pic.
#273 5 years ago
Hi guys ,I unplugged playfield.plugged in machine.motor moved 1/3 turn same two relays activated (S and V).motor stopped.also noticed that when I made switch contact with reset control relay switch. ( see pic).,two white wires.same thing.motor turns,same 2 relays activate,motor stops.at least I know power is running thru machine.
#274 5 years ago
Coin lockout coil on coin door should engage as soon as machine powers up. Thats normal.
#275 5 years ago
check your switch positions on the left target bank. Compare them switch by switch with the right bank (under the assumption that the right bank is correct. My guess is something on the target bank may not be opening when it should as the bank resets.
#276 5 years ago
There is an additional switch where I have circled. I'm not 100% sure but I think those close when all targets are dropped and open when targets are reset. If this stays closed even after targets reset, you might get the symptom you described with the constant reset.
a61a78f62fb8a8d55c3c3d99a8b5eed716621da5_LI.jpga61a78f62fb8a8d55c3c3d99a8b5eed716621da5_LI.jpg
#277 5 years ago
Pafasa,thanks,I checked switch.all switches.same as other side.middle reset switch closes when drop targets are down.replaced coils.had some for other game (5196s).no fuses are blown.what sends power to those coils.maybe there?.
#278 5 years ago
If it only overruns the motor when the playfield is plugged in, then we need to look for other things on the playfield that cause the score motor to run. I’ll look some more at the schematic tomorrow. Those drop resets are on the 25 volt circuit. Look at the bottom of the schematic and see what switches are involved in drop target reset. Start investigating there.
#279 5 years ago
Hey,thanks,I was thinking same.thats why i shotgunned pf earlier.i will also look at wires going to coils.just thought maybe it leads to score motor switch.i looked them over also.they seem adjusted fine.and drops did work in beginning.again thanks.will talk tommorrow.
#280 5 years ago
1) When you turned it on with the playfield installed, was a the playfield down and a ball installed in the outhole?
If "YES" then move on to question 2.
If "NO" then try the game again with a ball in the outhole, and then move on to question 2 if needed.
2) You said the game started but the motor kept spinning and it looked like target bank reset kept cycling. Did the machine send the ball to the shooter lane?
If "YES" and the game kept cycling even after the ball went to the shooter lane, then check the runway switch, (Located at G-3 on the schematic) between the outhole kicker and the shooter lane. That switch should open as the ball rolls over it on its way to the shooter lane.
If "NO" check the contacts on the outhole switch and the switches on the "O" relay. We need to get the outhole solenoid firing.
#281 5 years ago
The ball is in outsole, but coil did not fire.sorry,but I need to slow down.still havnt repaired drop target problem .and lower bank will not work either.thats why I was wanting to know if score motor switch controlled that.i see on schem drop targets are first off power source.but can't find where.i see wires off fuses,but do not know where other side should connect to main power source as schem shows unless I'm reading it wrong.the ball kicking out should be about last in reset cycle.i havnt got thru first step.
#282 5 years ago
I understand your concern. When you took the playfield off, the motor turned 1/3 and then stopped? If this is the case. I think we need to stay focused on the playfield. The constant drop reset may be a symptom of something else. If you checked all the drop switches and they are adjusted properly, I'd move on from that. Take a closer look at the outhole switch contacts making sure that they make good contact when the ball is in the outhole. Then look at the "O" relay and make sure all switches there are working as they should be.
#283 5 years ago
Hi pafasa,ok ,I'm with you now.i resoldered outhole switches.resoldered and adjusted switches on O relay.see pics.also both switches are closed when ball is just sitting in outhole.is this correct? I checked coil also.reads 15 ohms.i think I have power failure problem somewhere.what do you think.?
20181213_164650 (resized).jpg20181213_164650 (resized).jpg20181213_164802 (resized).jpg20181213_164802 (resized).jpg20181213_164809 (resized).jpg20181213_164809 (resized).jpg
#284 5 years ago
Hi guys,I've decided to start another forum to find my power failure issues.please stay tuned as I want to finish this forum to a complete working machine.so i will be updating this forum also .and will still be needing your help.again thanks guys for all your help so far.as soon as I find power problems,I will be back to continue where we leave off.the forum is called( Gottlieb big shot start sequence power issues).rolf Martin said he would assist me.he is expert in this area( dead wires), I believe.so please stay tuned.again thanks guys.
The Pinball Scientist
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-hot-shot-keeps-running-when-pluged-in-need-advice/page/6 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
