To be sure, look up the XO-295 but it sounds like it's probably there. Yes, pin 1 connects to C33.
Quoted from newtoit:on the product info for the amp it has a picture that looks like the one you attached with no heat sink. however the item description claims it comes with the attached heat sink. it references two part #'s. LM379 and XO-295.
Pin 1 is the pin leading directly to C33, correct?
Thanks for all your help. I posted this to a couple other forums and haven't received any assistance. I appreciate the time you are taking to help me sort this out.
No problem, I usually post to RGP as well but there hasn't been much in the way of System 80 tech help asked (Actually, it's been a little slow here too. This gives me time to catch up on other projects. ). I must have missed your post if you put one on RGP but posting here, I can use pics to help.
Steve
System 80, not just a job, it's an adventure
