(Topic ID: 260717)
Gottlieb Haunted House - Game Over Relay
By abcsindy
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by abcsindy
#1 4 years ago
I'm very near the end of a complete Gottlieb Haunted House restoration and I've run into an issue I can't resolve. Everything works - displays, sound, scoring...except solenoids. Basically no flippers, no slingshots - nothing solenoid controlled. I've traced it to the game over relay not engaging when a game is started, and if I hold in the relay manually all solenoids (pop bumpers/slingshots) work.
If I ground the Q1 transistor, the relay engages as it should. I originally thought the transistor was bad (tests good) or the driver board had an issue, so I swapped my Black Hole driver board but got the same result. I then swapped the BH MPU along with the driver board (changed the game ROM), but got the same result again. Self-test will activate the U relay but not the Tilt or Game Over relays. I can't figure out why the game over relay isn't latching when a game is started.
FYI - all ground mods completed.
TIA for any help.
#2 4 years ago
Maybe you could also try to swap the cable between MPU and driver board with the one from your Black Hole?
#3 4 years ago
Quoted from abcsindy:
TIA for any help.
Ball trough switch not registering?
#4 4 years ago
Quick update on this issue:
I've tried every combination of driver board, mpu, interconnect from my working BH, but still have the same issue w/HH. Ball trough switch is registering. At this point, since all grounds appear good, I probably need to break out the logic probe to make sure the transistor is being fired on the driver board. I'll update when I have more info.
#5 4 years ago
Problem Solved:
After taking every avenue to figure out the issue with my HH, it came down to having 2 pins crossed when I repinned the A2-J3 connector that attaches to the driver board.
Thanks to those that offered suggestions and hope this helps someone in the future.
3,950 (OBO)
Centerport, NY
Toast-Mach1 Mods Shop
$ 1,159.00
Daddio's 3D Printed Mods
$ 83.00
PinballReplacementParts
2,950 (OBO)
Shakopee, MN
$ 8.00
Tools
Nezzy's Pinball Prints
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-haunted-house-game-over-relay and we tried optimising it for printing. Some page elements may have been deliberately hidden.
