Working on a Gottlieb Goldwings. Have it booting reliably and playing just fine. I have two remaining problems of which no controlled lamps is a puzzle. I found no 6VDC at the bridge rectifier, and a small AC voltage going in. The fuse was hot but not blown. I don't know what the fuse value is but someone has replaced it recently with an unreadable value -- new fuse, likely from China. There is negligible voltage on the bridge outputs.
I pulled the fuse and measured the transformer outputs for the controlled lamp circuit and found a respectable 9VAC at the transformer lugs.
I test the bridge rectifier and it tests OK. I have seen this before with a bad bridge, so I replaced it thinking I have solved this problem.
But no, the problem remains. There must a short somewhere with the controlled lamps. I don't have a manual for this machine and until the manual arrives I would likely to isolate the problem somehow. With the fuse in place the AC measured at both the fuse and bridge terminals is
less than two.
What is the next step?
