Hey guys-
Just noticed the Ramp Motor in my Gottlieb Gladiators isnt working anymore. I've tried to engage the motor in test (listed as sol 22), but nothing.
Some things I've tried so far:
*I've tested for continuity across all fuses under the playfield and by the power supply
*I've tested Q23 and that looks to be fine (doing continuity test with ground), the manual has this going to sol 22
*I've measured AC voltage at the plug (A9J23) and was getting a constant 35V, in test or out of test, the motor is 50VAC
*I've bench tested the motor and it spins up
The one thing I've noticed is that the test menu shows the Ramp Motor as "Relay B", but I cannot find any such relay. The others I've seen (Q, T, etc).
I've tried looking through the manual I have, and really can't seem to find anything else to try, short of trying to hand follow the wire harness.
Any insight would be appreciated!
#gladiators
