Hi everyone,
I just picked up a Gigi from a fellow Pinsider and having some trouble. It was working when I picked it up, but I once got everything re-assembled, the playfield lights were not working. Everything else - flippers, bumpers, etc. seem to work fine.
I've worked on plenty of other arcade machines before but never pinball (and never something this old). This is my first venture - I appreciate you putting up with my n00b speak.
There are 3 fuses inside of the coin door to the left and 1 fuse under the playfield which all look ok. I have checked out the entire machine for loose wires and busted solder joints. I did find one which I fixed but no help. It was connected to what I believe is a coil, so probably not related to my problem anyway.
About 1 out of 20 times, the playfield will light up when the machine is powered on, but will only stay on for a split second.
The game is played so if you light up red lights 1-7 then hit the "speshul" the machine gives you a free game. When I do this, sometimes the playfield will light up, but only for a couple of seconds and then shut off.
I'm over my head here, and the guy that sold it to me lives a long way away, so any advice anyone can provide would be greatly appreciated.
