(Topic ID: 278476)
Gottlieb Genie -- Two flippers aren't working
By BRW84
  • 19 posts
  • 7 Pinsiders participating
  • Latest reply 3 years ago by BRW84
#1 3 years ago
I'm trying to fix a Gottlieb Genie for a friend and I'm beating my brains out. The lower right flipper and the upper right flipper won't activate. I've put new diodes on the coils and replaced the bridge rectifier for the solenoids, but no luck. It has a new-ish MPU and driver board, so I'm fairly confident the problem isn't there. Does anyone know what I should check next? Thanks!
#2 3 years ago
Quoted from BRW84:
Is this a new to you game or did they just stop working? Did you check the right flipper switch? Compare the voltage to the left side one with a meter. Some of games had soldered on wires on the flipper switches and others had crimped connectors. The crimped ones will fail over time and need some attention.
#3 3 years ago
Quoted from Mad_Dog_Coin_Op:
Is this a new to you game or did they just stop working? Did you check the right flipper switch? Compare the voltage to the left side one with a meter. Some of games had soldered on wires on the flipper switch and others had crimped connectors. The crimped ones will fail over time and need some attention.
I'll check that out! It's new to my friend and those flippers weren't working when he got it. It was also blowing the solenoid fuse because it had a bad flipper diode, but I fixed that already. Not sure if it was related.
#4 3 years ago
Follow the wires back from the right flipper switch. You might have a bad bridge or a flipper coil too.
#5 3 years ago
I'm thinking it has to be the flipper coil. My guess (and fervent hope) is that the bad diode on the coil that kept popping the solenoid fuse also fried the coil. I'll report back when I get the new coil on.
#6 3 years ago
Bad diode won't fry a coil. It's basically bypassing the coil.
You can test if the coil is good easily, just check resistance vs another similar coil
Upper flipper is activated by the lower one, so it makes sense that the lower not working would cause that.
#7 3 years ago
Quoted from zacaj:
The coil seemed to test within range (at least decently close to it), but when I first started working on the machine, the coil was wired backwards. Could that have messed it up?
#8 3 years ago
Also, I confirmed yesterday that the upper flipper does work if you activate the coil manually.
#9 3 years ago
Quoted from BRW84:
If the cool is wired backwards, the power is going to short through the diodes and blow the fuse and diodes.
#10 3 years ago
Did you file the right flipper switch to get it nice and shinny
#11 3 years ago
Quoted from plowpusher:
Oh yeah. The right flipper switch still activates the second of the two right flippers, so the problem isn't there.
#12 3 years ago
The end-of-stroke switch on the bottom right flipper is your problem.
#13 3 years ago
Quoted from KenLayton:
It looked pretty good, but I'll try replacing and see what happens!
#14 3 years ago
Quoted from BRW84:
It might just need cleaning/adjustment....
#15 3 years ago
Quoted from slochar:
I've cleaned the hell out of it, unfortunately.
#16 3 years ago
Several months ago I had the same problem on a Genie you are having with the flippers. I ended up replacing the end-of-stroke switches on the bottom flippers. No amount of cleaning/adjusting would fix them. After I replaced them, everything was fine.
I took a good look at the old switches after I took them off the machine. Turns out one of the switch blades was broken clear through *inside* the switch stack between the insulators.
#17 3 years ago
The upper flipper activates by EOS switch on lower flipper. So if your lower flipper does not work, neither does the upper flipper. Maybe the other EOS switch on lower flipper, that controls current to power winding of lower flipper coil is bad, and the flipper does not pull in with only the hold winding, thus not activating the upper flipper. So check that both of the lower flipper EOS switches are OK.
Flipper operating sequence:
- Flipper button pushed, current flows through lower flipper power winding, since the hold winding is shorted by normally closed EOS.
- Lower flipper pulls in, normally closed EOS opens, effectively connecting the hold winding in series with the power winding and lowering current to safe level.
- At the same time, the other, normally open EOS at lower flipper closes, connecting power to upper flipper coil (that has its own EOS to switch to hold mode)
#18 3 years ago
Man, I really hope this is the issue. It's about the only thing that makes sense at this point.
3 weeks later
#19 3 years ago
UPDATE: Finally got it fixed today, and this was the EXACT issue. Popper a new switch stack in there and it worked like a charm.
$ 89.00
That Old Pinball
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-genie-two-flippers-aren-t-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
