Need Help
I have a Genie that I have working except for the displays.
Upon power-on there are 3 different things that may happen seemingly at random
1) Displays work, but when the "Display high score" dip is set it alternates between a score and garbage (instead of "0" as I understand it).
2) Displays all show zero, including the credit and ball displays. Upon starting a game the displays show all segments (no score)
3) Displays remain off, not working at all.
Game plays normally other than the display issue.
When the displays are working, the display diagnostic works fine for all displays
All displays act the same, I know 1-2 & 3-4 are controlled in pairs, but issue effects all 5 displays.
Display power measures good.
What I have done:
1) Installed a Rottendog power supply
2) Installed a Rottendog driver board
3) Replaced the battery with a coin cell and diode (very little corrosion, local to the battery pads only)
4) Re-pinned the interconnect cable between the MPU & Driver boards
5) Installed a new GI fuse holder
6) Re-pinned the display connectors on the right of the MPU
7) Re-pinned the power connectors
