Hi all, I have finally added a system 1 to my collection, but when I purchased it, the scores were out. This game has new score boards and the PI-1 X4 board in it.
After quite a bit of research, this is what I've done in an attempt to diagnose the issue:
1. Checked pins 7 & 9 on the transformer. They read 73VAC, which is a bit high but seems fine to me.
2. Checked A2P1 pins 6&7 and they also read 73VAC, so it sounds like the high voltage circuit is working fine.
3. Checked A2P3 Pins 1&5 and get only 1.5VDC instead of 60VDC.
4. Checked A2p3 pins 3&5 and get only 0.61V instead of 42VDC.
5. Checked A2P3 pin 7 to A2P1 pin 5 and get 5V instead of 4, but this should be fine.
6. Checked A2P3 pin 8 to A2P1 pin 5 and get 8.38V, which is perfect.
This is where i'm stumped with online resources. I don't have a schematic or manual for the game, and pinrepair only offers "The 60vdc and 42vdc power lines come from the 69vac bottom board voltage" for info on the DC not being there.
Also, I did read in another thread that there are fuses that look more like capacitors on this board. There is a light brown one near the 60v LED. I pulled it and tested for continuity and didn't get any. I'm thinking maybe the 73V blew this fuse?
I've also read that the power supply has a pot to adjust the high voltage. Is this true, and if so, where would I find it?
Any help would be greatly appreciated.
