I have a Gottlieb Genie that none of the switches are working on. It has been totally repinned and has a Ni-Wumpf mpu, rottendog driver, and rottendog power supply. The game boots and will go into attract mode, but I cannot access the test menu nor will the credit switches or start button work. Also I tried hitting the switches on the playfield to see if the displays blink and they don't seem to be working either. The owner of the game said it was working fine and then it quit after he was messing with the coindoor. He brought it to me and the previous guy that worked on it installed a credit button on the bottom of the machine and ran two wires up and over the coin mechs down to one of the coin switches. After looking at those wires I found one that was pinched by the coindoor and pretty much cut in half. I'm pretty sure this caused the issue the game is having currently. Now on the Ni-wumpf board I have checked Z12, Z13, and Z14 which is in the switch matrix circuit via the test outlined on pinwiki on how to check 74xx series IC's. All of those IC's checked fine. The only other two chips in the switch matrix on the board is Z15 and Z16 which are LM339AM's. I looked online and couldn't find any info on how to check them. Can they be checked with the meter? The next steps I'm going to take is check all the switch matrix diodes and check continuity of the switches back to the J6 and J7 connectors to make sure none are stuck closed and to check there function. Is there anything else I should check or am I missing something here? I wish I had another system 1 to try the Ni-Wumpf board in, but I don't.
Here is the manual for the Ni_wumpf board
http://www.ni-wumpf.com/Gottlieb/System%201/NiSystem1Manual.pdf
