(Topic ID: 61113)
Gottlieb Geni help
By wadwerks
6 years ago
  • 15 posts
  • 5 Pinsiders participating
  • Latest reply 6 years ago by wadwerks
#1 6 years ago
I just picked up a Genie and have a few little issues I could use some help with. First off the right upper flipper is pretty weak I looked at the coils on both upper flippers and the weak one looks like a new A-17875 just like the lower flippers but the strong left flipper has a a-5141. Do I need two new coils or just one and if so what coils should be there. I also have 3 new a-20095's and trying to decide if I should use those for the lower flippers. Last problem is the only noise it makes is the na, naaa, na , naaa, naaa. Not really sure how to describe it other then that but if I hit the sound test switch it plays all other sounds, and some times it will play the sound when I hit the flippers. Is it possible there a switch some where that is supposed to make that noise that could be touching or gaped to close?
Thanks,
Jon
#2 6 years ago
Quoted from wadwerks:
All 5 flipper coils should be A-17875, as it says on page 18 of the manual. Pinball Resource should have them, as well as a manual for the game. Change all the EOS switches too, to eliminate them as being the cause of weak flippers.
Sound board may need to be re-capped. Should have the ground mod too. If the edge connectors for the sound board are factory, you definitely need to replace those. You may also want to try changing dipswitch 1 on the sound board (changes sounds). You may be missing only half your sounds. Power off game, change switch one on sound board, power game back up and see what sounds you have. Ground mod instructions are on pinrepair.com.
#3 6 years ago
Thanks,
Jon
If you hit the flipper and it makes a sound, is it also scoring as well? If it is, then see how many points it is scoring to help locate the stuck switch.
Jason
#4 6 years ago
Quoted from SchertzPinball:
Yeah, I may have misunderstood what he was saying. Genie has a bunch of 10 points switches. I bet it's one of those. Once that stuck switch is found and corrected, all the other sounds should come back.
#5 6 years ago
It does not score when it makes the sound and nothing is hit. I am going to do the ground mod in a day or two. Hard to tell on the connectors, if they are original they are beautiful but the inside of the cabinet looks like brand new and there is no corrosion on and connectors. The guy I got it from thought it was the sound chip so figured I would try everything else before trying to hunt one down. I do notice the once in a while when something is scored for a split second it starts to make the proper sound then that damn na, nana, naaaa naaaa kicks in. I tried changing the sound switch and it changes the sounds but still does the na, nana, naaaa naaaa sound the whole time just sounds different.
#6 6 years ago
Quoted from phishrace:
Fixed many system 1's and a stuck 10 point switch is very common. So many on most system 1's so need to check all the switches and wiring
#7 6 years ago
Quoted from pdman:
I've got a stuck 10 point on my Genie that I can't locate.
I had the same problem with my sound card on my Genie. I fixed it with a chime unit off eBay.
Jason
#8 6 years ago
Follow the green arrows. 7 total.
#9 6 years ago
The two coils the OP mentioned are interchangeable as I understand. I'm actually considering swapping the lower 17875 out in my genie and replacing with 20095s.
Wadwerks, if you decide to put in the 20095s, can you let me know how the game plays?
#10 6 years ago
Quoted from Vannos:
Both will fit, but as he noted, the A-5141 is stronger. The 20095's are even stronger. If you go with those, make sure to add some plastic protectors under the plastics on the lower playfield. On mine, with the factory coils, I can hit the top right drop target from the (lowest) right flipper. Doesn't crush it, but knocks it down just fine.
If the original poster is still reading, the lower the resistance of the coil, the stronger it is. All three coils are listed on the coil chart linked below.
http://www.pinballmedic.net/coil_chart.html
#11 6 years ago
Interesting, never been able to do that on mine I think i'll see if there's any excessive wiggle in the flipper, or give in the bakelite linkages. Maybe a things just need to be tightened up.
#12 6 years ago
The screw that holds the flipper bat to the lower 'shoe' often comes loose. If you can wiggle the bat side to side, that screw is loose. Retighten it using blue thread sealer. If the bats are cracked, PBR has new ones. Get the correct 3/8" lower rubbers and ribbed upper rubbers (both red) while you're ordering.
I do liberally wax mine. Pitch is 4.8 degrees between the flippers.
#13 6 years ago
I think there are more than seven 10 point switches. I'll check later today.
#14 6 years ago
Ok yea I get nothing when hitting the 10 point switches so might be one of those, I didn't know there where so many. I have also noticed that all my flippers seem to be weak so not gonna change them till I find the cause of the weak flippers.
#15 6 years ago
Well good news is I did find a closed 10 point switch. As it did fix the fact that the 10 point switches where not scoring it still continues to laugh at me with that sound.
Post edited by wadwerks : ooops
$ 289.00
1,750 (OBO)
Sale Pending!
Sayville, NY
€ 8.40
$ 69.95
COINTAKER.COM
$ 4.49
$ 79.95
$ 750.00
Great American Pinball
$ 42.00
$ 26.00
Pin Monk
$ 9,099.00
Little Shop Of Games
Various Other Swag
Tommy's Pins
$ 369.00
$ 29.95
Apparel - Unisex
The GameRoom Store
$ 40.00
Lighting - Backbox
