(Topic ID: 301541)
Gottlieb Free Fall Pic Needed
By Thrillhouse
8 months ago
  • 7 posts
  • 5 Pinsiders participating
  • Latest reply 8 months ago by jeffc
#1 8 months ago
Hi, I recently pick up a rough Free Fall but it has a Sky Dive backglass in it. I'm hoping someone would be willing to send me a pic of the backside of the Free Fall glass so I can see the differences between the two and map where the lettering and shaded parts go. Anything will do, no need for a ton of detail.
Also I'm hoping that someone can confirm a question on the 10x scoring red inserts. Does Free Fall differ from Skydive as fas as these work? The youtube vids I watched show that on Free Fall 4 stay lit at a time and switch sides every time a 10 point switch is hit, Skydive only has 1 lit at a time moves with center pop hits. I'm still chasing the gremlins out of the game and not sure the correct way things should work.
Thanks in advance
#2 8 months ago
Sky jump works as you say. The center pop moves the light along the drops. Freefall swaps the 4.
#3 8 months ago
"Sky Dive" is the export add-a-ball version of "Free Fall", and should function pretty much the same as the domestic version. Not to be confused with "Sky Jump", which is the domestic replay version, and has a different rule set.
#4 8 months ago
Quoted from Thrillhouse:
Are you sure you're seeing videos of "Sky Dive", and not "Sky Jump"?
#5 8 months ago
Thank you both for the responses. Yes I meant Sky Jump and not Dive, sorry for the confusion. Bump for a pick of the back side of the backglass.
#6 8 months ago
I believe that Sky Jump has one target lit at a time in 5 ball, but 2 at a time on 3 ball.
#7 8 months ago
Quoted from jasonspoint28:
Yes, Sky Jump has one 10x light in 5-ball. But one or two 10x lights in 3-ball, depending on the CON (1) / LIB (2) feature adjustment setting.
$ 5.95
The EM Scientist
Various Novelties
GC Pinball
Apparel - Unisex
Pinball Wheezer
