You can try to zoom on pix here: http://www.ipdb.org/machine.cgi?id=949 and confirm by wire color. Number units will be in the backbox. No letters on the coils?
Most of those are easy to place. For example, the primary fuse and bank set-up fuse labels. Poke around a little. You should be able to find the center pop bumper relay easily. The score reel ones are self explanatory. The alternating relay shouldn't be hard to find either. Some of the others might be a bit of a challenge, but I think the one at the bottom of the photo is from a score reel. Check all the reels to see if others might have a similar tag on them.
Primary fuse - fuse next to transformer
Bank setups - under playfield slow blow fuses
ten thousands, thousands, etc unit - score reels
inside, second, third - the switches on the top of a score reel
inside, second - ball count unit?
There's a few that are in the list of relays in your image. The relays should have yellow stickers with letter:
center pop relay - Q under the playfield
1st ball relay - V
100,000 point - J
Alternating relay - F
etc
Lockin switch I can't place off the top of my head.
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-free-fall-factory-label-locations and we tried optimising it for printing. Some page elements may have been deliberately hidden.
