Hey guys, I'll try to keep this short..
Recently, the rear up kicker and shooter lane kicker solenoids work very rarely during gameplay but always during test mode or when a ball gets stuck, triggering the solenoids after 15 seconds or so..
Both are set off by leaf switches which seem to be in good condition. I recently replaced the MOSFET for the shooter lane solneoid because that stopped working, it's used for multiball, worked like a charm after replacing the MOSFET but recently started acting up again along with the rear up kicker behind Freddy's head.
What do you recommend I check out next? I'm new to pinball so I'm not sure what would cause solenoid issues during gameplay but not in test mode other than a fauty switch, which im not sure how to test anyway, to see if that may be the issue. I should also note, it's not that they never work during gameplay, in fact, ill get a good run in when everything works like it should but then some games, they rarely, if at all, work.
