(Topic ID: 263440)
Gottlieb Four Seasons 1968 - kicker too powerfull, ball hitting glass
By arthurl
#1 4 years ago
On a Four Seasons, I've recently added a glass pane above the playfield and realised that some of kickers (4 out of 7) were bouncing the ball too hard / too high, so the ball hits the glass and I'm afraid it will break it. Even if there is no risk of breakage of the glass, the sound it makes is not very nice, so I'd like to fix it.
Do you have any generic tips on how to reduce/adjust the kick of the kickers in such a case ?
Taking a look at the metal parts I saw that part of the plates had usage dents in them (red contour points to that), and I thought reducing that dent with some material (tape to start off testing) might help, reducing the swing of the part. Is that a valid approach ?
I've read that the adjusting the solenoids might be a solution, adding resistance ? For the top 5 kickers they are moved by two solenoids, and the bottom two by one solenoid each (which are activated together).
Can anything be done on the metal parts ? Bending ? Filing ?
Thanks in advance for any tips.
IMG_20200306_101516.resized (resized).jpgIMG_20200306_101516.resized (resized).jpgIMG_20200306_094641.resized (resized).jpgIMG_20200306_094641.resized (resized).jpgIMG_20200306_094654.resized (resized).jpgIMG_20200306_094654.resized (resized).jpgIMG_20200306_101450.resized (resized).jpgIMG_20200306_101450.resized (resized).jpg
#2 4 years ago
Your machine might be set to high tap making coils too powerful. http://www.pinrepair.com/em/index3.htm#perform
Are the springs present on those metal plates under the playfield? If not, add them.
#3 4 years ago
And I wouldn’t concern yourself with the wear or slight bends on the kickers... yet. Normal and shouldn’t cause ball to hit glass. The tape can also be removed. Make sure it’s on normal tap and all the springs are present and go from there.
I have a game with those kick outs as well.
#4 4 years ago
I had a similar problem after I restored the playfield on my space mission. I took it off high tap, but thought it was still kicking too hard. I called PBR and Steve sold me a coil that was weaker. It kicks great now and doesn’t hit the glass anymore. Give PBR a call.
The Pinball Scientist
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-four-seasons-1968-kicker-too-powerfull-ball-hitting-glass and we tried optimising it for printing. Some page elements may have been deliberately hidden.
