just got a gottlieb fast draw pinball
when it turn the power button on it all lights up but the game over relay and the 1st ball relay switches are both stuck on .i checked the switches in the score motor since i saw that the score motor switches 3a and 1 c have to do with both these relays
i looked at the switches and cleaned to contacts,at least i think i cleaned the right switches and they seems to be making good contact when needed,after i cleaned the switches the switches are still stuck on . anything else to check .
Also there is a single wire coming from the "score motor " motor with a single "pin" plug on the end.when i first got the game this pin plug when plugged into the slot that did not have a wire soldered to it .nothing was happening ,so i plugged it into the slot next to it ,this slot had a yellow wire with red tracer soldered to it and the score motor cycled and then stopped in i believe the rest position to start a new game ,is this the right slot that it should be in ?
anyway the game over relay and 1st ball relay are still stuck on ,thanks in advance for all the help
