Quoted from chuckwurt:Looking for relay schematics that show each relays for my jungle queen and whether the switches in them need to be NO or NC. I have a schematic from PBR that doesn't seem to cover this. I also have the games manual. Noting there either.
Maybe I'm just reading this schematic wrong. Is there somewhere that explains how to read GTB schematics?
The only place this would be is in the manual. Not all manuals (especially gottlieb's shitty ones) show it though. You can technically tell from the schematics by finding the correct switch by wire color and checking if the symbol there is NO or NC but it'd be a pain.
In general though you shouldn't need to use anything to verify this, unless you've taken all the relays apart for some reason. Just look at which side of the switch is the longer one that goes into the slot on the moving plastic piece. A normally open one needs to have the long one away from the coil, a normally closed needs to have it closer to the coil.
