Hm, I would like to see/know where he got his information from. Never heard that one before. As far as I know, the only factory made games came with the purple cabinets and any James Bond cabinets that had Eclipse playfields and backglasses were conversions on route.
It has some of the same rules as Black Hole with regards to getting multi-ball. Hit the 4 yellow stationary targets on the right and then get the ball into the lower right saucer to trap it. Then you need to hit the 4 stationary targets left/center of the playfield with the next ball to light the upper ball trap (same spot to sent the ball down to the lower playfield on Black Hole). Then you have send the ball up there and plunging the next ball onto the playfield starts multi-ball. That's where the rules change.
While you're in 3 ball multi, everything on the playfield scores 3X. When you lose one ball, the playfield scores 2X. All drop targets add to the bonus IIRC. The play is fast because of the obstructions in the center of the playfield. You have less time to react to a ball rebounding back at you.
To get the bonus 5X scoring, you have to start by sending the ball into the lower left saucer, this gives you 2X. Then you have to knock down all the drop targets in order, starting with the 3 drop targets in the middle right of the playfield (3X). The 4 drop targets on the right then give you 4X. The 5 drop targets on the upper left give you 5X.
I forget how you get extra ball.
There's a lot going on and things can get too busy for some players to follow. I think that's partially why there isn't a big following for this game. That, and the sounds aren't that great, IMHO, they don't really match the art/theme. Still, that said, it's a keeper for me and I play it a lot when it's set up.
Quoted from GizzArd:He said its a kit done by the factory since the ran out of cabs so they just used the James bond ones. Lol well I'm lookin for a challenge soooo.... this may be it. How's the fun factor. Does it want you to play again and again
