(Topic ID: 237888)
Gottlieb Double Action Ball count advancing to many times
By smohr
5 years ago
  • 7 posts
  • 2 Pinsiders participating
  • Latest reply 5 years ago by smohr
Gottlieb_Double_Action_Relay_Legend.pdf (PDF preview)
Gottlieb_Double_Action_schem1.pdf (PDF preview)
#1 5 years ago
Good Afternoon,
I got this Gottlieb Double Action breathing again after cleaning all steppers and score reels. It scores the correct amount of points. The game over match function works. The issue I am having now is the Balls Played Unit advances too many steps, skips over Ball 2.
Game is setup for 3 balls per game.
I press the replay button once. For 1 Player.
I am able to get a good start-up sequence.
score reels reset to zero
replay unit decrements 1 game
Ball 1 is displayed on backbox
Ball is released
"O" relay is latched on.
I score some points and then I drain the ball
"O" relay is unlatched and "P" relay is latched on
Then the Balls Played Unit advances to Ball 3 and Player 2 score reels become active.
I score some point and then I drain the ball.
Game Over
Im not understanding the schematic and what would be causing this. Not sure where to look at this point.
Any thoughts/ideas/suggestions is greatly appreciated.
thanks
Steve
#2 5 years ago
Quoted from smohr:
Can you post the relevant section of the schematic?
#3 5 years ago
Hope this is usable... - Thanks
Gottlieb_Double_Action_schem1.pdfGottlieb_Double_Action_schem1.pdf
#4 5 years ago
Can you also post the relay legend? (what each letter corresponds to) Thanks.
#5 5 years ago
Sure, that would help, sorry....
Gottlieb_Double_Action_Relay_Legend.pdfGottlieb_Double_Action_Relay_Legend.pdf
#6 5 years ago
I am looking at the circuit of ADD BALLS PLAYED..
2 switches on TB1 were not even close to being adjusted. I am now able to register the correct ball being played and also the scoring is being scored to the correct player and it also seems to work correctly when selecting 2 players.
Now im looking into why at "Game Over" I press the replay button to start a new game and nothing... I have to unplug the machine in order for it to work.. I'll start another thread if needed...
thanks
Steve
#7 5 years ago
Im gonna mark this as resolved. I was able to play about 10 games (single and double) and the add balls played worked fine.
as for the "Game Over" issue, once I put the pin back together (I had a few switches loose for adjusting) that issue went away... for now, lol
thanks
Steve
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-double-action-ball-count-advancing-to-many-times and we tried optimising it for printing. Some page elements may have been deliberately hidden.
