Although there is no 500 pt relay, there are two relays on this game that allow for the scoring of 500 pts. One is the V (roto-target scoring) relay, and the other is the Y (hole) relay.
However, before getting into those, the first thing I would check is the most simple potential issue, and that is the score motor 1D switch stack. There is an N.O. switch on that stack that is only supposed to close during the first pulse of the 1A switch to score 100 pts when the X relay is energized. If the score motor 1D switch is making contact all of the time, you will get 500 instead of 100.
If the motor 1D switch is working correctly, then you'll need to look at the Y relay and the V relay.
The Y relay is the easier one to check. The Y relay pulls in when the ball enters either kick-out hole. The X relay always pulls in along with the Y relay. There is a switch on the Y relay that closes to complete the circuit across the score motor 1D switch, so that the X relay will score 500. If this Y relay switch is closed all the time, you'll always get 500 points instead of 100 points from the X relay.
The V relay always pulls in when either roto target is hit. If the current roto target matches the lit domino, then the X relay will also be energized along with the V relay to score 500. Each roto target switch consists of three blades, which all must be open unless they are being actuated by the ball. Check to confirm that you don't have two blades touching all the time on either of the roto target switches. If you do, then actuating the X relay from any PF switch can also pull in the Y relay to score 500, but only if the roto target on the faulty switch happens to match the lit domino.
- TimMe
