Hey all you Gottlieb gurus...
My hat off to you for starters!
My credit wheel lands between numbers, and I cannot see what is causing it, or how to correct it.
I have looked it all over, and found the subtract lever to be the stop point for the clock gear.
There is it seems, no adjustment for that, as the arm on the pivot is a fixed length.
So, if thats "home", then the wheel numbers will line up between themselves on each advance, or step back.
What am I missing?
I have moved the advance stop, only to make it worse, and need to return it to ts original position.
The assy steps up/down easy, but lands between numbers. Help, obiwan
