I have a Gottlieb Magnotron EM with a bad coil in one of the Decagon score wheels. The coil reads infinite resistance and the plunger is stuck or frozen in the solenoid. I have a correct replacement A-9154 coil. Can I replace the coil without completely removing the score wheel. I would prefer doing it while the wheel is still soldered to the chassis (I of course know I will need to de-solder the old coil and re-solder the new one). Just trying to avoid removal of the 20 or so wired connections to the wheel.
Thanks in advance,
Tom
