Hi
I recently picked up a Gottlieb Cross Town.
The pop bumper coil is toast and I do not have any paper work.
Does anyone know what coil to use so I can order one from PBR?
None of the pop bumper coils have numbers on them either
Rick
Hi
Rick
Quoted from Malibu-SS:Hi
Rick
4893 you can tack on the cir dia at the same time. and your hold relay is probably toast too 9736
https://www.pinballmedic.net/coilchart.html half way down to Equivalent Gottlieb Solenoid & Relay Coil Substitution Chart
If the bad coil has a fiber bobbin, look on either side of the coil terminals. The number will be embossed into the fiber. You may need a flashlight and a small mirror.
Quoted from Silverstreak02:When you call PBR for the coil you should order a wire print. You’ll need it again.
Yeah that is the plan!
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-cross-town-pop-bumper-coil and we tried optimising it for printing. Some page elements may have been deliberately hidden.
