(Topic ID: 284280)
Gottlieb Countdown With All New Boards Help Needed
By Pinheadpreacher
#1 3 years ago
Just installed all new boards in a Gottlieb Countdown (Rottendog power supply, Ni-Wumph MPU, and rottendog driver). On power up everything looked good. I selected Countdown as the game. In diagnostics, all switches work/test correctly, displays test correctly, all lights work, solenoids work except #8 (Red Target Bank Reset). However, if I manually ground the transistor for the Red Bank reset the solenoid fires and the targets reset.
If I try to start a game, the games gives the initial tune, resets only one bank of targets. Flippers and pop bumper work. However, nothing else works. No displays, no switches, no controlled solenoids, only non-controlled solenoids.
Sort of stuck as to why everything works in diagnostics (except solenoid #8) but then nothing works when starting a game.
Any ideas would be appreciated. Thanks.
One other note, I had a spare original System 1 board with a Countdown ROM. Not sure if it was completely working. However, I did install it back in the game and I was able to start a new game with everything working except two of the target bank solenoids were stuck on.
Also, I have re-pinned all the connectors.
Johnie
#2 3 years ago
Did you put a ball in the game?
#3 3 years ago
Yes. I've tried with and without a ball.
#4 3 years ago
The below post is from the PBR about the Ni-Wumph CPU. Read the very bottom: *Note
NI-WUMPF Gottlieb® System 1 Mark II CPU Board
The NI-WUMPF Gottlieb® System 1 Mark II Replacement CPU Board supports all 16 System 1 Games! This board is a technological pinball breakthrough for System 1 owners!
The NI-WUMPF Replacement board
GTB-A1-A $209.00ea
*Note: The above board is only compatible with original Gottlieb® Boards, Ni-Wumpf Driver Board, and/or GPE Power Supplies. Suggest checking with Ni-Wumpf before using with replacement boards from other vendors.
#5 3 years ago
Also, did you replace this harness?
#6 3 years ago
GJM: Thanks for the replies.
Yes. Brand new Docent Electronics harness between CPU and Driver Board. Re-pinned all connectors.
I've used the Ni-Wumpf in a Totem with the Rottendog power supply without any issues. Power doesn't seem to be the issue as it boots correctly and the setup and diagnostics all work like they should.
I just don't know enough about the Ni-Wumpf to know if I have an issue with it (maybe I blew out a chip on it) or maybe I have a switch matrix issue, though all switches test correctly in the diagnostics.
I've contacted Ni-Wumpf but haven't heard back from them.
Thanks,
Johnie
#7 3 years ago
There is a thread going on right now about some issues with Rottendog products. I know the thread isn't about their driver boards but maybe something that has not been reveled yet. Here is the title to the thread:
WARNING to Rottendog WDB089 owners - Check it now!
Maybe your CPU doesn't like the Rottendog driver.
#8 3 years ago
You have an old driver board to try in it?
#9 3 years ago
I think I have a couple of old driver boards that might not work completely but that at least work enough to see if it is the driver board. I'm going to go out back (my game room is in a converted detached garage) and play around with it some more. Thanks for the help. I post some more follow-ups after I've played with it some more.
#10 3 years ago
Quoted from gjm:
Quoted from Pinheadpreacher:
Yup, great way to test. If you want to try or have time/skills. You can rebuild your driver board with a kit from BDE or GP or self put together.
#11 3 years ago
Figured out the issue. It was actually two different things. First, tried the new Ni-Wumpf with an old original driver board and it had the same symptoms, worked fine in diagnostics except solenoid #8. Then when I started a game it would play the start up tune, reset the green targets but nothing else, no displays, switches, etc. would work. I had a old system 1 CPU and a Countdown ROM so I used it with the original driver board and the game worked except solenoid #8. So, the issue has to be in the new Ni-Wumpf. In fairness to Ni-Wumpf I've used their boards successfully in the past. This particular board, while never having used it, I had in storage for over a year. It's possible I did something to mess it up so I don't want to throw any "shade" their way.
As for solenoid #8, it ended up being the CPU to Driver connector. It was a brand new harness I bought from Docent Electronics so I assumed it was good. However, one of the pins had come out. It was the pin that sent the signal to solenoid #8 (A1J5-2). I pushed the pin back in and everything worked.
Long story short, it seems that I had two brand new pieces (Ni-Wumpf and the wiring harness) that had issues.
As a side note, you may be wondering why I was putting new boards in the game if I had old ones that worked. I was restoring this game for a lady and I wanted to make sure that it was as "bulletproof" as it could be. I figured new boards would be better than using the 40 year old boards I had even if they were still working. Plus my boards had been "hacked" a little over the years.
Anyway, thanks to all that tried to help.
#12 3 years ago
Update and correction. There was NOT anything wrong with the Ni-Wumpf board that I used. It was user error. I feel pretty dumb once you hear what the error was. I've been restoring games for 16 years and I work as a computer programmer, so the mistake I made was really dumb. It was like the person who calls into tech support and is told to turn their computer off and on and it fixes the problem or the grandma who call tech support once a week because she can't remember how to get solitaire to play on her computer.
As for the issue, it seems I didn't have a game selected. In my defense, and it's a weak one, with the Ni-Wumpf, the first thing you do is go to the Game Select option and it gives the 16 System 1 games that you cycle through until you find your game and then select it. Well, COUNTDOWN is the very first option and I thought it was selected. It seems that it wasn't selected. So, I re-initialized the board and went to game select mode and cycled through all the games until it came back to COUNTDOWN and then selected it. After that, everything worked.
$ 89.00
That Old Pinball
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-countdown-with-all-new-boards-help-needed and we tried optimising it for printing. Some page elements may have been deliberately hidden.
