I wanted to ask if any of you have ever replaced the A 9738 Continuous Service Hold Relay coil with one of those current reproductions.
The problem arises that the coil works immediately well, but after a while it heats up it starts vibrating, so much so that it almost sounds like a bell buzzer (at lowered it is still bearable but at raised floor it stuns you)
The pinball machine being a 1975 already mounts the second type reels or without washer. Even when recovering the Washer from another old type coil, the difference is important we are in the order of about a millimeter, so much so that it does not attract the anchor.
Measured without a washer, the old one measures 25.6mm, the new one 24.4mm.
Will it be enough to shim with a 1 mm washer?
I attach photos
