Hello,
We have a close encounters of the third kind pinball that is having some issues with the rotowheel. It rotates as it should when triggered to do so, but rarely does it register a score when you hit it. I have done some investigating and it appears to me that there is something out of adjustment. when the wheel stops the targets are off by enough that they end up between the contacts behind the rotowheel. So when you hit a target it is not contacting things behind it and registering. If we pull the glass and hold the targets in their proper position and then press the targets they score normally.
I looked at the gear that drives the rotowheel and it does not look worn as best I can tell. Can someone please let me know if there is a way to adjust the rotowheel to correct this? If there is no adjustment can someone tell me what they suggest to reconcile the situation?
Regards,
Chris Farmer
