I'm having problems with a gottlieb cleopatra. About half of the insert lights are locked on. Someone has previously replaced the MPU with a Ni wumpf pcb0001 Rev C. (Around 1999 or 2000) I've already repinned the interconnect, checked a13 lamp transistors as well as all of the 74175s. When put in the lamp test, the locked on lamps pulse slightly. For whatever reason, I can't get onto Ni wumpf's website, not sure if it's down for maintainence or they're closed. If someone has either the manual or schematics for this board, it would be much appreciated.
