Hello,
I have been cleaning up and restoring a Cleopatra and I have one issue left that I cannot pinpoint. The 1000's chime is not working correctly and it's behavior is very odd to me. When playing a game the 1000's chime will fire initially and then it seems that it does not have enough juice to fire again. The 10's and 100's chimes are just fine and fire without issue.
For example, I put the machine in test mode and for the 100's chime I can press, press, press to get ding, ding, ding. But when I advance to the 1000's chime and press, press, press, I get ding, slight plunger movement with no ding, even less plunger movement.
After a minute or so I can repeat the test with the same results. I have tried different driver boards (2 old original, and one new rotten dog replacement) with the exact same results. The connectors in the head have all been repined (fun!). The power board is reading correctly at contact points and firing 2 of the 3 chimes ok.
Could it be the 1000's coil? I would think it would just not fire at all if that was the case.
I appreciate any help you can offer to me!
