(Topic ID: 188035)
Gottlieb Charlie's Angels Ball in Play Display light dim. Solution?
By StotzBotz
6 years ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 6 years ago by StotzBotz
#1 6 years ago
Hello folks. I was wondering if anyone knew of a way that I can make the ball in play display any brighter. The number shown is very dim. Is there an associated capacitor that might make this occur? All the connections are good. I did the 12 volt charge method to the larger displays where you apply 12 volts to the 2 outer pins on the displays and it did help them some but I was told that you can't do that with the smaller display for the Ball in play. Any help would be greatly appreciated.
#2 6 years ago
recharging the smaller display works the same way but you use a lower voltage. if you have a power supply you can control voltage and monitor the current easier with around 9V but even a 9 volt battery should work. i alway did in very low light and make sure the filaments do not go past a nice orange color.
#3 6 years ago
Thanks for the info. I tried it with a 9 volt battery but didn't see much of a change.
$ 4.00
$ 7.50
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-charlies-angels-ball-in-play-display-light-dim-solution and we tried optimising it for printing. Some page elements may have been deliberately hidden.
