(Topic ID: 247778)
Gottlieb Caveman coils fire at power on
By CUJO
11 months ago
  • 10 posts
  • 2 Pinsiders participating
  • Latest reply 11 months ago by CUJO
#1 11 months ago
Well, Caveman just started to do this yesterday:
When the pin is turned on, all the coils fire immediately & I think some stay locked on.
I looked inside the coin door and I can see the free game knocker fire and stay locked until I power off. I see the pop bumpers all fire once and all the insert lights come on and stay on. I dare not let it stay on for more than 2-3 seconds so I power pin off immediately to avoid frying coils or transistors.
I am not very familiar with Gottlieb issues like I am with Bally/Williams, so any suggestions what to check first would be greatly appreciated.
#2 11 months ago
Read the Pinwiki and do the ground upgrades.
Check the connectors for bad pins.
http://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_80
#3 11 months ago
Quoted from Inkochnito:
Thanks for the reply. I did ground the connector between the MPU board and the DRIVER board some time ago from TNT's youtube video but that's the only "extra" grounding work I have done. Do you really think that my issue is because of the GND issue? This is a really clean game so doubt it's acid or corrosion.
I have already pulled, wiped connectors w/ soft cloth and reseated all the connectors in the backbox. Funny thing is it did this lock up thing Saturday AM, came back later in afternoon and it started fine. Played a great game. Powered off pin. Went to turn it back on Sunday and back to that coil fire lockup sound as soon as I flip the power. It's definitely not forgiving this time.
#4 11 months ago
So I am thinking about buying a Rottendog MPU080 MPU board. Not sure what I need to fix this lock on THUNK issue but the replay knocker fires and stays on. The GI flashes briefly, then all the insert lights come on and stay on.
I'm no Gottlieb expert and from what I read they can be a real headache to work on so was hoping that the Rottendog may be the way to go?
#5 11 months ago
Update: Ok, this Caveman is possessed. Turn on this morning, all is fine now. Go figure. The F11 fuse was blown so replaced with 2A SLOBLO.
I did go thru the bottom cabinet yesterday, tightened up all the grounds and I do have the newer pair of capacitors in there someone replaced before I got pin.
Anyhow, another question for someone with a schematic.
My 5X insert light only works if I pull the top edge of Connector A3-J3 out just a smidge. Push the connector back on firmly, the 5X insert light will not work.
Which pin on that connector do I need to inspect, clean or change that controls the 5X light?
THANKS!
CuJo
#6 11 months ago
Here is a piece of the schematic....
I'll send you a PM with something more.
#7 11 months ago
How odd....
I think they made a mistake in the schematics.
A3J4 in this case should be A3J3.
The board schematic is correct, but the light assignment listing isn't.
#8 11 months ago
How odd....
That is a good catch. It is labeled wrong in the manual, isn't it?
What does the little "544" mean? So it's pin 5 on the connector?
Thanks so much!
#9 11 months ago
Quoted from CUJO:
Thanks so much!
544 is the color of the wire.
It is a white wire with 3 stripes on it, 5 (green) 4 (yellow) 4 (yellow).
Pin 5 of connector A3J3.
#10 11 months ago
Pin 5 of connector A3J3.[quoted image]
Thanks Peter!
€ 8.40
$ 289.00
$ 8.99
Dr. Dave's Pinball Parts
$ 63.50
3D MODS
The MOD Couple
$ 899.00
$ 5,899.00
Operation Pinball
$ 7,499.00
Nitro Pinball Shop
$ 149.00
$ 89.99
$ 69.95
pinballmod
$ 5.00
$ 7,999.00
Little Shop Of Games
$ 399.00
Bent Mods
$ 28.00
$ 29.95
$ 5,899.00
$ 6.00
