I have cleaned quite a few of those units over the last few years and haven’t needed to mess with the spring or replace gears. This post was the key one that helped me:
https://pinside.com/pinball/forum/topic/gtb-as-match-stepper-rebuild-step-by-step
In my experience, the key thing is to get everything clean, followed by making sure everything is aligned correctly and the little arms are not dragging on the axle at all. The switches that ride on the cam (if present) must have as little tension as necessary. I also do super lube the circuit board wipers (very little) and the switch cam. When they’re done, they should step nicely like little clocks.
There are 2 adjustments noted in the gottlieb documentation. One talks about the little blade that makes sure that it can’t step backwards. You don’t want that one pushing so hard into the gear that it adds a lot of drag. The other one rotates the cross piece to make sure that the “throw” of the armature is the right amount to allow it to click to the next spot on the gear.
Sorry for all the words. I think it’s harder to explain than to actually do it, once you’ve been successful. I was really frustrated and stuck on the first one that I did, but practice did help.
Good luck.
Dave
