(Topic ID: 252615)
Gottlieb Card Whiz (1976) BX Relay Question
By Silver_Balls
7 months ago
  • 4 posts
  • 2 Pinsiders participating
  • Latest reply 7 months ago by MarkG
#1 7 months ago
Recently picked up a Card Whiz with several issues and making a lot of progress. Now zeroing in on specifics. The issue now is that the BX (Last Ball Relay) is constantly picked, humming loud, There are 2 coils on the BX relay, the one humming is the A5662 coil on the underside looking down into the cabinet.
I thought I would pose this question before purchasing a relay to see if that is really the problem. Is there another component causing this to be picked? Or is this the cause??
I do have schematics and getting better at interpreting them however I could use some guidance on this.
Any suggestions are greatly appreciated.
SB
#2 7 months ago
The BX relay is an interlock relay that is intended to receive pulses on either coil to set or reset (or latch and trip) the relay. Essentially it toggles between two positions given an appropriate pulse. Neither coil should be given constant current.
The humming is telling you that the relay coil is fine, and whatever is sending current through it is at fault. So which coil is active? The BX coil with a slate-white wire on one solder lug, or the BX Reset coil with a yellow-black wire on one solder lug?
Either way, you should trace back through the schematic to figure out which switches to examine to find the one that is apparently stuck closed.
/Mark
#3 7 months ago
Thank You Mark, it seems that when manually engaging the start relay the BX relay engages until I manually engage any other relay such as the 500 point relay, then the BX relay is normal. many other problems await, the add credit stepper is frozen in place, all score reels are filthy and sluggish, pop bumper works but doesn't add score.
This pin sat in a garage for 2 years without being turned on, bought it on CL for $300. Playfield is average, inserts cupped, cabinet decent, backglass minimal flaking. I think I need to start at ground zero and clean all switches, score reels, steppers, & everything else before getting too caught up in specifics.
I resurrected a Sure Shot project last year and took about 4 months. Just got Card Whiz last week and attempted to take the fast lane to get playing, not going to happen.
I will check back when I do my due diligence.
#4 7 months ago
I agree. Sort out all the mechanical issues and have a good look for all the obvious electrical issues first. Once you can get all the score reels and steppers to behave by just pushing in their plungers and verify that all switches can open and close, what's left to sort out will be much simpler to diagnose.
Various Novelties
GC Pinball
COINTAKER.COM
$ 44.99
Lee's Parts
$ 26.50
The MOD Couple
$ 65.00
G-Money Mods
$ 28.99
Lee's Parts
$ 150.00
Professor Pinball
$ 199.99
$ 29.95
Pinball Photos
$ 69.99
$ 7,499.00
Great American Pinball
$ 48.00
$ 218.00
$ 369.00
$ 79.95
$ 25.50
$ 22.00
Apparel - Unisex
Silverball Swag
