(Topic ID: 174738)
Gottlieb Buck Rogers with Pascal PI-1X4 coil issues
By focusmediagroup
7 years ago
#1 7 years ago
I picked up a Pascal Janin PI-1X4 board for Buck Rogers and installed it and am getting a number of coil fails. The first coil test fails so it won't boot further. Says the coil is stuck on. The flippers and pop bumpers are working but most other coil tests fail stating they are stuck on. The coils are all in great shape and wiring and switches seem ok. The failing coils are the Outhole, playfield outhole, knocker, and both target banks. I am not sure what I should try from here. Does anyone have a solid order of things I can work through? Are some of the diagnostics available on the Pascal board helpful to do more diagnostics on how to resolve? I am new to repairs so start from the very beginning. Let me know if you want any pics.
#2 7 years ago
I would try contacting Pascal Janin in France. He has the reputation to help his customers.
I also have a Buck Rogers on the back burners and I was thinking about going your route with the Pascal Janin board. This is not a good omen....
Yves
#3 7 years ago
Quoted from Arcane:
I'm sure it's an issue specific to the OP's game, and not an inherent issue with the Pascal boards.
Quoted from focusmediagroup:
With System 1 games, connector pins are usually a problem area--even if you replace the original boardset, you still normally have to address those. Also check continuity for the ground wires to the board.
#4 7 years ago
This game had a power issue was blowing boards before. Maybe diodes? It's interesting, all the board controlled coils seem to be working properly (pop bumpers/flippers/slings) but the solenoid list that aren't board controlled are messed (except the tens/hundreds/thousands). It isn't the board, just need to figure out what to do first here.
#5 7 years ago
You have it backwards
Pop bumpers, flippers and slings are not controlled at all by the boards.
All of your other solenoids are controlled by the the boards
#6 7 years ago
Ok thanks, I guess if one connection is off it could cascade causing more failures and locks. I may check that.
1,400
New Brighton, PA
$ 89.00
That Old Pinball
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-buck-rogers-with-pascal-pi-1x4-coil-issues and we tried optimising it for printing. Some page elements may have been deliberately hidden.
