First post so here goes, I did search best I could before posting.
First pin to own is this Buck Rogers in amazing cosmetic and mostly mechanical shape. Things I've already done:
*Ground Boards to back plane
*Replaced "the big capacitor" on PS.
*Added LED to PS, MPU +5 -12, add LED to Driver for +5 indication.
*checked for +5 and -12 at MPU, adjusted 5v pot it was at 6v.
*replaced Kicker Transistor TIPS-102 and burned up coil.
*replaced 5 bank drop target coil (#8) and MPS-45 and 2N3055, replaced MPS with a CEN-45 from Mouser.
*All LED (frosted) on playfield and back glass.
*Confirmed proper fuses and function.
Once I did all above things worked fine. Played about 40 games then bam, 5 bank drop target won't reset. It gives about a 1/2 effort like it would come up then stop. I tested by grounding the 2N3055 and the target would pop up. PS felt pretty warm on the heat sink. Let it cool and worked about 4 games then same thing. Found the CEN-U45 was out, replaced and worked fine for about 10 games. BAM out again.
So my question is this, what do I need to look for? is this a voltage issue? I'm stumped. Getting tired of replacing this transistor too!
Fun game family loves it.
