Hello,
After a month of searching I am finally just gonna ask for help. Finishing up this game. Just having 2 small score related issues.
1.) on player 1 (single or 2 player doesn’t affect it) when P1’s ball drains a mystery 50 points is added, now it’s odd as say for example there are 51 points on the score when said ball drains, it’ll go 61, 71, 81, 91, 01. So the issue doesn’t trigger the 100’s reel to advance as it rolls past the century mark. This occurs all 5 balls P1 only when in 2 player this doesn’t not happen to P2. The game does trigger the 100pt reel to advance normally with playfield scoring.
Here is what I have verified, the 50pts is not coming from the 50 point relay, blocked it’s contacts still occurs, it’s also not the 10pt relay did the same thing there.
2.) this issue happens almost always and exclusively to player 1 ball 3 drain, in single player mode, when that ball drains, P1 gets the 50 free points, which as I showed above can actually set you back. However on this situation 1 solitary point is added to the second players scoring. This does not occur in 2 player.
Any ideas are appreciated…..
In my mind it seems to possible be linked to the reset wheel motor in the cabinet or possible something in the ball unit?
