After starting with 100 problems or so on my Big Top, I'm down to just two, so I'll start a thread for each one and perhaps I'll have it working completely in a couple of days.
As a 2 player Add-a-Ball game, this one is unusual enough that the problems I've been having are ones that other people haven't had before here, making it impossible to search for a solution.
The latest issue involves the A-B-C rollovers on the playfield.
Gameplay:
1. The top rollover is always lit for either A, B, or C, and it changes every time it's hit.
2. Hitting that top rollover lights the corresponding letter on the lower rollovers labeled A, B, or C. So if the top rollover has "A" lit, and you hit it, then the lower letter "A" will light.
3. Hitting the lit lower rollover awards an extra ball.
The upper and lower A-B-C lights are working correctly, as are the latching relays U/UR, V/VR, and W/WR. The switches on the relays are adjusted correctly and the lights work correctly. Hitting the top rollover when lit for A, B, or C lights the correct lower rollover as it should.
Problem: Hitting the lower rollover does not award an extra ball, and the Continues to Play unit does not advance.
I'm having trouble following the schematic for this, though it appears that the L (Rollover Series Relay) and C (Continues to Play relay) are involved.
This one's probably easy, but I can't figure out exactly where I should be looking to find the solution to this.
Schematic is here: https://images.pinside.com/5/d0/ae/5d0aec1798e673fc2776bdc816244ba9c0ef8a13.pdf
