Can a Big Shot or Hot Shot owner confirm correct operation? On my game, when the outhole kicks the ball over to the shooter lane the trough switch under the apron causes the score motor to run and causes a second firing of the ball return solenoid, even though there is no ball in the outhole. It is causing the player unit to not always advance to the next ball since the score motor is running. Any time the trough switch is activated....by ball or manually under the playfield the score motor runs and the outhole kicker fires. I am guessing I have a fault that is allowing the second outhole kicker activation
