(Topic ID: 249797)
Gottlieb Big Shot EM - Score Motor +
By tcw16505
#1 4 years ago
Hi Pinside Friends. I would enjoy your thoughts or direction. Just picked up a #Big Shot yesterday and found the score motor running continuously as well as a Roto type unit that could be keeping track of ball count or what ever, see photo (I have ordered a schematic from Marco). Also the " Tilt Hold Relay " pulses with the Roto unit while still being energized and then every cycle it de-energies for one score motor pulse. Your thoughts or direction would certainty be appreciated.
20190818_215433 (resized).jpg20190818_215433 (resized).jpg20190818_215451 (resized).jpg20190818_215451 (resized).jpg20190819_223648 (resized).jpg20190819_223648 (resized).jpg
#2 4 years ago
Start by figuring out what is making your Score Motor run. These are all of the switches that can make the motor run:
Any one of them could be stuck closed or have its solder tabs touching or some other kind of short. Examine them all to see if you can find which one(s) are stuck closed.
The letter on each switch corresponds to a relay. You'll have to find each relay in the game and look for the Normally Open switch that connects a brown-red wire to a red-white wire in the relay.
The last switch (Motor 1C) is on the Score Motor itself. It follows the upper cam and is in the switch stack in the #1 position.
/Mark
#3 4 years ago
If you do not find any switches that appear to be incorrectly gapped on the above relays described by Mark, while the score motor is running, check all of those relays to see if any of them are energized. As you can see from the schematic, they are "normally open" switches which close when the relay is energized. You need to work backwards through the schematic to find the root cause.
#4 4 years ago
Quoted from dr_nybble:
Thanks for your help Mark. To your point Dr, "C" the "Add Bonus Unit Relay" is energized. Where to next guys?
#5 4 years ago
Quoted from tcw16505:
Where to next guys?
I would check the make/break sw. on ZB and the other switches involved for cleanliness and proper gap.
#6 4 years ago
Is this switch on your Bonus Unit? Does it open?
If not it could keep your C relay active. It's barely visible in the upper right corner of the schematic currieddog provided.
#7 4 years ago
Sorry to say there was a little more going on than I realized. What I missed was that HB, ZB, QB1, QB2 were latched. After resetting them I powered back up and they again energized.
#8 4 years ago
Quoted from MarkG:
It has a tag on it that says Runout Switch and when the cam allows the contact is open.
#9 4 years ago
So to summarize:
Coils Energized or Latched
C (Add Bonus Unit Relay)
HB (3000 Bonus Value Relay)
ZB (1st Player Relay)
QB1 (Game Over Relay)
QB2 (Game Over Switches)
and a rotating Runout Switch/(Bonus Unit?) unit that actuates over and over along with the
Score Motor that runs continuously.
Added over 5 years ago:
Any ideas on what these might have in common?
#10 4 years ago
Ok, while looking this over today and resetting the RESET BANK (HB (3000 Bonus Value Relay), ZB (1st Player Relay), QB1 (Game Over Relay), QB2 (Game Over Switches) it actually stayed clear. It now stays just like that but now its doing something completely different.
Three things remain the same as before
1. Coil C (Add Bonus Unit Relay)
2. Rotating Stepper (Bonus Unit?) Solenoid w/attached Runout Switch that steps over and over.
3. Score Motor that runs continuously
Coil O (Ball Return Relay)
Coil Q (Ball Return Control Relay)
Coil A (Alternating Relay)
The targets reset and ball return runs over and over with the Rotating Stepper (Bonus Unit?)
I can't wait for this wiring diagram to arrive! In the meantime your help is greatly appreciated. - Tom
#11 4 years ago
Sometimes trying to find things that need to be adjusted or replaced can be quite frustrating on a EM pin. I do not know your EM diagnostic level but if I were you I would wait for the schematic to arrive and learn how to read it if you don't know already. Then go to "pinballrepair/em.com" and read from start to finish what Clay has to say. He is one of the best in the game for diagnostic/repair. He will also tell you the start up sequence. Follow that sequence with the schematic in hand to run through the process. For any parts you might need for your Gottlieb pin call Steve Young at "The Pinball resource" (PBR) for all your needs, he is the cheapest most stocked guy around for Gottlieb parts. While you are waiting for the schematic go to Clay's site and do some reading on EM's.
Lastly, did the pin work 100% and this started after transporting it to your house?
Once again, I do not know your level of EM repair and I did not mean to apply you know nothing, I just wanted to give you my opinion on how I would start the diagnostic procedure. Good luck and have fun with the pin.
#12 4 years ago
The C relay is likely the cause of the other two. Have you gone through the schematic that currieddog posted in reply #5 to figure out why C is firing? You can put folded bits of paper between the contacts of various switches in that circuit to figure out whether or not they're part of the active circuit.
Also, it would be helpful if you could verify whether the handwritten portion of the posted schematic matches your game.
#13 4 years ago
Quoted from MarkG:
Also, it would be helpful if you could verify whether the handwritten portion of the posted schematic matches your game.d
Mark, Thank you for the thoughtful reply. Shortly after sending this my schematic arrived and I came to the same conclusion regarding C. I had a concert date with the wife so I hope to get started on this tomorrow figuring what's up with C and I'll also verify the hand written portion as well. I'd be interested in knowing why the error in the first place and how far in production they got before the correction.
#14 4 years ago
Quoted from MarkG:
Well I didn't see this the first time through. There was damage to one of the contacts on C, a NO contact that was permanently closed. 20190825_143709 (resized).jpg20190825_143709 (resized).jpg20190825_143740 (resized).jpg20190825_143740 (resized).jpg After straitening that out the game is silent.
As I coin up I hear the Credit Unit Assembly actuate and but no credits show on the wheel. While manually actuating the numbers they never quite make it to the front viewer so its blank. Regardless when pushing the replay button nothing happens. I will begin to look as for why the "S" relay doesn't engage.
As far as the hand written part of the diagram if the contact that interacts directly with the ball rollover is NO with no ball than it has not been updated right?. 20190825_124823 (resized).jpg20190825_124823 (resized).jpg If the ball enters the ball return it then closes. So is my interpretation correct here, not upgraded? - Thanks again for your help! - Tom
#15 4 years ago
Usually the Credit Unit should only step between zero to a maximum number of credits (often 14?). If it's taking steps but what's shown in the window doesn't change you may be past the limit switches in the weeds. If you're not familiar have a look at the video at https://www.funwithpinball.com/exhibits/small-boards#CreditUnit to see how it should work.
#16 4 years ago
Quoted from MarkG:
A great explanation of Credit Unit operation. Mine is jacked. The contacts where apparently not limiting the set direction limits and the spring is wrapped around more than it should be and the contacts are all bent up as well. Getting the contacts back where they belong will be a challenge to figure out. Mostly for the same reason most things on this machine are, wire identification. You would swear the wires where out in the sun for 30 years catching a tan in a humid climate based on the amount of corrosion is on everything else electrical. My toughest EM to date though its only my third.
So was my interpretation correct here, not upgraded to the handwritten portion of the posted schematic?
#17 4 years ago
I don't know the back story of that revised schematic nor do I have a Big Shot to compare against. I don't know if the factory changed things or if someone revised his own game and that schematic got out into the wild. That's why I asked you to compare against what you have.
The only other EM schematic revision I'm aware of came out on official letter head from the Engineering Dept.: https://ipdb.org/showpic.pl?id=890&picno=40318
#18 4 years ago
Quoted from MarkG:
Gotcha. Seems it wasn't updated to the hand written revised schematic. I have been a bit distracted with a fence project in the yard which I just finished yesterday (about 350 feet worth).
Present Status: Can't coin up. Three relays close in the Control Bank as I turn the power on, two have coils. Its ZB,(1st Ball Relay) QB1 (game over relay) and then consequently QB2 (game over switches) is pulled in with QB1. It seems this game has a number of issues.
#19 4 years ago
That's normal.
If the replay button doesn't activate the Replay Button (V) relay, Inspect and diagnose this circuit with Alligator clip jumper wires
http://www.planetimming.com/Pinball/troubleshooting/EM%20Troubleshooting.pdf
http://www.pinrepair.com/em/index3.htm#features
#20 4 years ago
Quoted from HowardR:
That's normal.
http://www.pinrepair.com/em/index3.htm#features[quoted image]
Good call! I need to do further examination however I held in "V" contact in and pressed the credit button and it worked. I powered it off and just pressed the credit button and it works now and kicks the ball out. It must have been some corrosion.
That said the score reels are not recording a score (no chimes either) even though I can hear the score motor running. After hitting the credit button I can hear a reset taking place but the numbers are already zeroed out. Also it does not recognize the ball when it drains to advance the ball in play.
#21 4 years ago
@howardr @markg
So here is the latest snag on this. If I score anything that involves "1st Hundreds", "ZB" locks in and consequently the "Ball Return" will no longer function. So is the a normal operation of the circuit and the circuit path is then ment to pass through the bonus unit?
FYI: The mysterious hand writen part on the diagram (involving Coil "Q") is not pysically part of this game (If it did would it resolve this?).
Thanks for your continued support on this troubled game. - Tom
#22 4 years ago
When activated the ZB relay should trip and stay, but if the ZB coil locks on, check this switch
If the Ball Return solenoid doesn't activate when the Ball Return relay activates, Inspect and diagnose this circuit with Alligator clip jumper wires
pasted_image (resized).pngpasted_image (resized).pngpasted_image (resized).pngpasted_image (resized).png
#23 4 years ago
Sorry, I didnt mean to imply the coil is energised, it isnt, just locked.
I was looking hard at Solenoid "Q" due to the "Ball Return Sw" in that circuit. So when I saw "ZB" being energised I thought there might be a problem with that or with the "Bonus Unit" completing the circuit. Still getting my legs on circuit logic.
I will begine to check out contacts on "O", Motor Contactor #4, Level C and "XB".
#24 4 years ago
I will begin to check out contacts on "O", Motor contactor #4, Level C and "XB".
Contacts and connectivity are just as stated in the drawing. Proper voltage was also being applied through XB to the associated side of Motor 4C contact which was open as well as O.
After coining up and closing the NO Ball Return Switch, Q (Ball Return Control Relay) energizes and consequently the Ball Return solenoid fires as it should. However after scoring 100 points or a multiple thereof ie 500 Points ZB contactor energizes and then latches. This then opens a pathway to Q preventing the Ball Return solenoid firing.
There is another path that should be working though and its through the Bonus Unit.
I checked the Bonus Unit mechanically at first. It was sluggish and not snappy at all when actuated. I replaced two springs. This is when I noticed two wires had become entangled with the Bonus Unit Auxiliary Contacts. They were holding the contacts apart. This may have been a self inflicted wound when I had the play-field out leaning against the pin, I'm not sure but this machine was a real rescue and challenge seeing it had of 24 separate issues preventing it from operating. It had seen abuse, heavy corrosion, damaged components and foolish attempts in its past to repair it. Its a real joy to have it working completely now. Thank you all!
#25 4 years ago
If I recall, the bonus unit steps 15 times when the ball drains to test which drop targets are down. Is that happening?
#26 4 years ago
Yes, it is. However, as I have played about 10 games on it, it will at the start of a ball or mid game stop scoring and ringing the chimes. The 8 Ball hole kicker will not function when this occurs also. When the ball drains it will score and chime any bonus collected. This is intermittent. Often times the next ball works fine.
It might be a strange approach but the 8 Ball kicker circuit seems easy to me so I will wade in at that point and see what I find.
#27 4 years ago
It might be a strange approach but the 8 Ball kicker circuit seems easy to me so I will wade in at that point and see what I find.[quoted image]
It didn't take long for it to happen and I got it to repeat a short time later and both times I found this. The Score Motor is cut short on it's full rotation cycle. So, contact “Motor 1C” must need the gap adjusted. I'll give that a go and see what happens.
20190927_153423 (resized).jpg20190927_153423 (resized).jpg20190927_153527 (resized).jpg20190927_153527 (resized).jpg
1 month later
#28 4 years ago
I am experiencing something very similar with a big shot I just got. At power up, ZB triggers and coil C locks, score motor spins nonstop. I checked and don’t see any touching switches at C. If I reset ZB it just trips right away. I have a video but cannot figure out how to attach it.
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-big-shot-em-score-motor- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
