Well bros, i got Big Injun to fully work again, it had the "endless reset spin" syndrome and also some stuff was wierd with the switches, but the culprit was the tilt-switch on the coindoor, somebody had pulled it apart when it was supposed to be together, making the game insane.
Also had to bend back some metal on the target area, since the magnet relay couldnt reach the plate, and clean several switches all over, and glue back one of the plastics "knobs" on the player count that was broken off so a whole stack of switches didnt get activated, resolder some 2-3 loose cables here and there, fix one of the switches on the Ball count relay (contact tab was broken clean off so i had to solder a small cable on the leaf switch).
Still need to switch out one of the bakelite flipper arms, the one on the left is kinda "fixed" with wire but still works, and a backglass translite is done, just need to pick it up.
IMG_20181024_140056 (resized).jpgIMG_20181024_140208 (resized).jpgIMG_20181024_140224 (resized).jpg The culprit of the whole problem, the coindoor tiltswitch. IMG_20181024_140330 (resized).jpg
