(Topic ID: 256700)
Gottlieb Big Hit Tilt issue.
By SteamVette
  • 12 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by SteamVette
#1 4 years ago
Hello all. I’m working on my Gottlied Big Hit. When I got the machine the R relay was dismantled and the coil was missing. The H relay was dismantled and had wires connected together ect. The machine worked somewhat, but not completely. Game was stored for over 20 years. I bought two new relay coils and I “think” I have it soldered back correctly. When I power the machine on it resets all the score reels to zero and takes a credit off. The tilt light stays on and no game can be played. I checked all tilt slam switches and they appear to be in check. I have it set up on free play and you can toggle a new game. Not sure if I still have a H or R relay problem or there was another problem back in the day and that’s why they started taking them apart. Any help is greatly appreciated. Thanks
#2 4 years ago
Quoted from SteamVette:
The Make-Break switch on the Reset Completed (AX) relay is responsible for activating the Tilt Hold (H) relay during game reset. If that's not happening, Inspect and diagnose this circuit with Alligator clip jumper wires
http://www.planetimming.com/Pinball/troubleshooting/EM%20Troubleshooting.pdf
http://www.pinrepair.com/em/index3.htm#features
#3 4 years ago
Thanks Howardr. It appears the AX relay works just fine. All contacts are adjusted/cleaned correctly.
#4 4 years ago
Did you check all of your tilt/slam switches?
#5 4 years ago
Quoted from currieddog:
Yes.. I checked the door, head, playfield and bottom main board.
#6 4 years ago
Then the Tilt Hold relay is activating?
#7 4 years ago
Quoted from HowardR:
Its running the score motor, but I don’t see it activating the H Tilt Hold relay.
#8 4 years ago
Did you read the links I put in my post #2?
#9 4 years ago
Hey Howard, So I'm still new and learning this EM stuff. So i apologize for my ignorance up front.
Grandbabys came over so i had to stop the pinball work. So are you saying run a jumper from the AX relay brown/white/red wire to the silver/white/red wire on the H relay?
#10 4 years ago
If you'd like to try a phone call, send me your cellphone number in a private message and I'll make a first reply with a text message.
#11 4 years ago
Update: This switch on the Hold (R) relay needed adjustment.
#12 4 years ago
Howard is absolutely amazing! Explains things in terms even I can understand.
My next issue is some of my lights (all in pic) don’t work. Looks like they go through that dang H relay.
9EC34661-9286-49DE-A5A3-13B853A73CD7 (resized).jpeg9EC34661-9286-49DE-A5A3-13B853A73CD7 (resized).jpeg
Covington, LA
$ 12.00
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-big-hit-tilt-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
